allwthrrider
Jan 18, 2019Explorer
After cleaning & fixing a few minor issues plus working on eliminating as many rattles as possible I did change out most the light to LED's.I will finish that portion first thing when I get it home. Second thing i need to work on is setting it up for winter use. going to order heat blankets for the all tanks & wrap all waterlines with heat tape. I'm thinking of mounting 4 golf cart batteries in the lower compartment with a diode on the charging cable so they will be dedicated to the purpose of running a small inverter to power the heat blankets & water line only.
The fwd tv has already been replaced with a 42 in flat screen above the fireplace & the rear tv I removed because it was one of those "Boat Anchors" & wife & I don't believe in tv's in the bedroom, I'm thinking of installing a small safe in it's place.
