allwthrrider
Feb 12, 2019Explorer
Well heres a update, Got called Jan 29 that the coach was all & ready for pickup, Great I'll fly out on the 31st & pick it up. Got called the 30th "Hey still has problems the solenoid valve for extend side of bedroom slide is failing now & slide keeps creeping out" Great lets go ahead & replace that too. So ended up fly to SLC on Feb 9 got to the shop and as I'm checking everything out I put all the slides out, okey I bring them in nope, the left fwd slide won't come in, Since its Saturday they have to call the tech in that worked on it turns out that since the retract solenoid was replaced on that slide apparently the pressure was to good with new pump & all it blew out the extend solenoid. So 2 guys lifted the ends of the slide to get it up then I was able to retracted it with the pump, So got on the road & now its back in CA, I have to order another solenoid but I'm thinking of just replacing the rest of them at the same time. New ones have a simple lever to flip to release pressure instead of dealing with a socket & ratchet.
