Tramp844's avatar
Tramp844
Wood rot
Not knowing much about motorhomes and the fact this 1993 allegro bay 27.5 class c motorhome was free , i will ask this question. Before i got this rv there was a water leak on the left side in the bunk over the cab. The wood inside the wall is rotted bad. Is this a fixable thing ? if so how is it done ? or is this something that will junk this coach ?
This is the outer wall over the drivers side.
Yes this rv has some problems, needs a new hot water heater,a new AC , water line under bathroom sink , a battery , cab ac repair , front end work and marker & tail lights not working. Now this wood rot thing. I have a long way to go. :(
  • There was a member recently who had work done on the front side of his fifth wheel. Very good job and inexpensive.
    Four years ago in Florida we had a leak in the front of our previous travel trailer. It had a window but the running light up above was the culprit. The rv repair said it would be $3200 to take off the skin and redo the whole front cap.
    I think you will find some very good and reasonable prices. Of course, if you want it to look like new, sure you'll pay a premium. I'm not that picky.
  • Kevin , if you can send me a link to those threads. My search comes up with "0" matches for rebuild cab over bunk wall. Tks.
  • Bill, thank you for scaring me to death. :o !!
    kevin, i think so the outer fiberglass is delaminated. and thin wood is falling out . the wall paper stuff inside is also comming off.
  • Use the forum search feature - s/b a few lengthy threads with pictures on guys who had to re-build their cabovers ... should give you a feel for what's involved. Are you sure that the interior wood is rotted and not just the thin veneer stuff that covers the interior wall -- the later is easily replaced.
  • You've got two ways to go.
    One depends on your age/physical condition and carpentry, plumbing, electrical and so forth skills are. I would say you're going to have $5,000 into it using your own labor.
    The other one depends on how strong your wallet is. This will run you $15,000+. It will cost a lot of hours for a shop to take the walls and roof apart to fix the rot. The water might have even gotten down into the floor. (100 hrs of labor (minimum) at $100 per hour and $5000 for materials.)
    Bill
