We decided to get a Mr Heater Big Buddy. It can take either 2 of the small propane tanks or has adaptability for larger tanks. Propane stays good forever and I found 3 100 pound propane tanks on craigslist for 100.00.  I think this is a good deal.  We tried out the propane tanks and the Mr. Heater this weekend. 2 of the little tanks lasted about 7 hours on low.  That seems like it went through the gas.
We also made an attempt to repair the roof.  The drivers end has a leak in the roof.  We think the 1986 Bounder originally had a metal roof but someone along the way painted on a rubber coating of something then someone else (or maybe the same person) painted on several coats of a silver stuff that sort of disintigrates when you try to remove it.  We scraped off as much as we could and painted on the elastic something or another paint and hope this works.  Our regular house has a flat roof so we have the black rubber stuff on our roof and I wondered if this would work for an RV????
Other items, I found the house battery.  Thanks to whomever suggested it might be up front with the engine battery.  I could not find any switch that makes the RV stop using the house battery.  The date on the battery was 2011 so I'm sure it's dead and gone.  It's an Everstart Maxx 29 Deep Cycle Marine battery.  Since I need to buy a new one (there is room for two) I'd like some advice on a good deep cycle battery to buy.  Is the Maxx 29 a good one?  We also want to install a solar panel kit to keep the batteries trickle charged.  I've seen lots of different kits on ebay and amazon for anywhere from 150.00 for a portable up.  We'd like to spend around 400.00 for a panel or two and inverter and charge controller.  Is this reasonable?
There is a panel which tell the status/levels of the gas, propane, fresh and grey water tanks but it isn't working and I assume this is because the house battery isn't working.
The electrical panel has some unlabeled switches (located above the panel not in the panel) but since the house battery isn't working, I couldn't tell what they do.  The console by the steering wheel also has a couple of switches (and a toggle switch) that are unlabeled so I'm in the same boat with them.  Would love to provide you with photos but photo bucket doesn't seem to like my photos and won't upload them. You can try here.
http://s344.photobucket.com/user/zen4pamela/media/1019141342b_zps91ca9e10.jpg.html?sort=3&o=0[/img]
or
http://s344.photobucket.com/user/zen4pamela/media/1019141341_zps0ca430da.jpg.html?sort=3&o=1[/img]
or
http://s344.photobucket.com/user/zen4pamela/media/1019141342c_zpse85c4e00.jpg.html?sort=3&o=0
Will keep trying to upload on photobucket.  Let me know if the above links don't work.  In the mean time, we have to put another coat of the white rubber paint stuff on the roof.  Remove the satellite dish holder and the antenna holder (can absolutely do without the garbage on television) and figure out how to seal up those holes.
