rgatijnet1
Feb 28, 2018Explorer III
With your Actia dash you can program it to give you your oil pressure reading. Mine used to run about 45 psi at normal cruise and drop down to 15 psi or so at idle.
As mentioned, the Actia dash sometimes will go crazy. To reset mine I just flipped the chassis battery disconnect switch.
