wildmanbaker
Feb 28, 2018Explorer
I'm just punching holes in the sky here, but it may be an oil drain-back problem. Something is restricting the oil from draining back form the heads. Plugged drain back holes, wrong gaskets, etc. The oil smell makes me think this may be the problem. If you are climbing, you are at a higher RPM, which puts more oil in the top end. Possibility.
