theoldwizard1
Feb 28, 2018Explorer II
You need to verify that the sending unit is working properly. The only way to do this is to remove it and temporarily screw in a mechanical gauge. Hot idle oil pressure is the most important. You should be able to buy a mechanical gauge for less than $50.
If your original sender WAS working properly, damage likel has already been done to your engine.
