berfle's avatar
berfle
Workhorse Allison Jumped from 5 to 6 Speed (on its own)
I have a 2010 Bounder 33u on a Workhorse Chas is with Vortec 8.1 and Allison 5-speed (approx 26,000 miles). I've read that the 5-speed can be changed to a 6-speed but this is pretty strange. We've been on the road for several days and 2 days ago I noticed that the dash display is now showing 6 speeds. Also maybe my imagination but when it goes into the 6th speed, it's smoother and quieter (as if it's shifting into OD).
  • If you search the medium duty GM trucks like Kodiak you will find info about the Allison having 6th locked out and a way to enable 6th. Many people with the truck based motorhomes have done it.
  • wallynm wrote:
    What does the tac say? Any drop in RPMs?
    What actual Workhorse chassis do you have? If it's the "W" series I do believe all Allison transmissions that were installed from 2005 and up have the 6 speed transmission. Now if it's a "P" series chassis it may have something different.
  • I believe that in 2005 the Allison 1000MH transmissions ALL went to 6 speeds. By 2010, you already had a 6 speed transmission from the factory. If it was NOT shifting in to 6th gear, which is a double overdrive(5th and 6th are both overdrives), it is because of some problem with the transmission control module(TCM).
  • What does the tac say? Any drop in RPMs?
