rgatijnet1
Oct 26, 2014Explorer III
I have the same Workhose chassis and knew about the problem from previous posts. I cut the top intake horn off of the intake plenum. I turned it 180 degrees and attached it back on the plenum with a couple of screws through two pieces of sheet metal on the inside. I then wrapped the joint with duct tape and with the intake horn now facing the rear, it is a non-problem. That was 70,000 miles ago.
