Impeyan
Jul 11, 2014Explorer
I know about pressing the brake and I did that as always, even a little harder this time. I was parked flat and not on any kind of hill.
The steering wheel turned freely but I will remember to lift the front off the ground should this happen again.
I found what I think is the brake interlock and I will remove the 2 separate plug ins (one with 2 wires and one with 3 wires)should I get stuck again.
Unless there is a trouble code stored, I am wondering if having it inspected would do much good ??
On the other hand, just to replace all the possible parts may not make sense either.
Not sure of the chassis but the build code (2010) says W32018.
Thanks for the replies.
38,768 PostsLatest Activity: Jan 26, 2021
