carringb
Jul 11, 2014Explorer
Brake pedal switch can cause this. It has several circuits, some normally open some normally closed. The interlock circuit may not be the same as the brake light circuit. You can test it by pulling the plug, and using a multimeter to check if continuity changes at the proper pins.
38,768 PostsLatest Activity: Jan 26, 2021
