msmith1199 wrote:
Rollnhome wrote:
“Light Class Motor Vehicles” are defined as any motor vehicles using use fuel (diesel) on the highways of this state except for use class vehicles. Use class vehicles include a road tractor, a truck tractor, a truck, having a declared gross vehicle weight of more than 26,000 pounds or having more than two axles or a passenger carrying motor vehicle designed to seat more than 20 occupants."
This is copied from the state law. I read it as two axle MH over 26K are classified as Light Class Motor Vehicles.
Then you read it wrong, because that is not what it says. It says have a "declared gross vehicle weight." That is not what the vehicle currently weighs, that is a weight that appears on your registration that is the total weight intended to be carried on that vehicle plus the weight of the vehicle. In
California a DGVW is only required on commercial vehicles.
We are talking AZ not CA.
A MH is not a road tractor, truck tractor, a truck , having over 26k DW , more than two axles, or designed to carry over 20 passengers.
An RV is not a truck and does not have a declared weight. Therefore exempt from the higher tax.
