Rollnhome wrote:
The weight (GVR) rating on my Arizona registration is O0000. Therefore I have O declared weight rating. I have two axles. I use the lower cost fuel. Never been a problem for over 10 years. Dutch- ascribed means assigned. My weight has been ascribed on my registration as 00000. 00000 is less than 26,000. Check your registration weight.
My coach's registered weight and the published GVW are both under 26,000, plus my rig is a gasser. Show your registration to the AZ Tax Evasion folks when/if they tag you using the wrong pumps. Let us know what they say. I just posted links that show what the applicable AZ regs are. Not being a lawyer or a judge, I'm not qualified to determine just how those regs are interpreted or applied by those charged with enforcing them. Perhaps the fellow that recently got nailed for the $1k fine will tell you what his registration says.
