irehc77's avatar
irehc77
WTB Atwood G6A 6E water heater
Looking for a used Atwood G6A 6E water heater. Our tank was cracked when we purchased this used 89 Georgie Boy. Really only need tank but will also purchase whole assembly. Also possibly interested in newer furniture for this. Has the jack knife couch and also the jack knife dinette and one swivel captain chair. Please email me at jon_cheri@kaltelnet.net if you have available for purchase.
  • Thank you both for your replies. I will contact Bontragers. White Pigeon is quite the distance but found there web site so I can call. As far as welding the split is huge. But thank you for the part number for replacement tank.
    Tank is aluminum and can be welded to fix.
    Tank replacement is Atwood 91641------Reference chart
    All replacement tanks after 2006 use a 3/4" NPT T&P RELIEF Valve
    prior to that they used a 1/2" NPT
  • Check with Johnsons or Bontragers rv surplus in White Pigeon, Michigan. Last time I was there they had plenty, better yet go there, you will probably find more things you didn't know you needed LOL, kdk
