dougrainer
Feb 13, 2016Nomad
1. The Wire Nut is not the correct gauge for the amp connection
2. The 2 wires are NOT tight in the wire nut and are slightly loose and that cause minor arcing and heat build up on high amp current draws. Which gets worse as the wires get hot and more loose until it melts the wire nut. Make sure you strip back the burnt wires until you get good clean shiny copper. Doug
