nemo45
Feb 13, 2016Explorer
hershey wrote:nemo45 wrote:You know that by doing this, there is no fused protection in that circuit except for the shorepower breaker.rgatijnet1 wrote:
You ARE using the inverter when plugged in to shore power. It is called pass thru current and it will trip the circuit breakers on the inverter if you exceed the limits.
I knew the current went through the inverter when on shore power. If you do the wiring yourself that is quite evident. The breakers on the inverter did not trip. In fact no breaker on the motorhome tripped. In order to remedy the problem temporarily I just pulled in wires and the out wires and connected them together and bypassed the inverted. But, before we leave to go back up north I want to wire it back up properly. I think the remedy will be the crimp typed connectors.
That is not true. There is a 30amp breaker on that whole inverter circuit and each of those outlets in that inverter circuit are on a 15 or 20 amp breaker.
38,782 PostsLatest Activity: Sep 18, 2026
