msturtz
Feb 13, 2016Explorer
Depending on where the inverter is installed it may be due corrosion if it is in an outside bay it may be subject to humidity that can cause the wire nut to corrode which increases the impeadance. This increased impeadance creates heat. The solution is dielectric grease. That will solve the problem.
38,782 PostsLatest Activity: Aug 11, 2021
