nemo45
Feb 14, 2016Explorer
msturtz wrote:
Depending on where the inverter is installed it may be due corrosion if it is in an outside bay it may be subject to humidity that can cause the wire nut to corrode which increases the impeadance. This increased impeadance creates heat. The solution is dielectric grease. That will solve the problem.
I ordered butt connectors with heat shrink on the ends and I have a tube of dielectric grease. I think these will take care of the problem.
38,783 PostsLatest Activity: Sep 23, 2026
