John___Angela
Jul 18, 2014Explorer
Canadian Rainbirds wrote:
I have a Xantrex Prosine 2.0 If the batteries are low it will charge at 96A (The level I set) then decrease.
I suspect you have a battery issue.
You can set the charge rate to what the max the battery should have.
You still didn't answer what "era" is. That's new to me too.
Yepir. If your batteries are low 100 amps would be normal depending on how many batteries etc. The "era" thing I don't know. Is it reading "error". If so does it have an error code?
