RayChez
Jul 18, 2014Explorer
If you have the Xantrex 458, you are probably turning on the equalizing feature. If you are you got to be careful because the amps go way up and you could toast some of the fragile electrical boards.
If you press SETUP AND CHARGE at the same time on the panel it will start the equalizing of the house batteries and your LED lights which shows the charging will go way up to around 14.5 volts.
