ichudov
Jan 12, 2015Explorer
Xantrex inverter would not turn OFF???
I have a 2003 Monaco Windsor RV. It has a Xantrex inverter.
Recently, the weather had been quite cold (which may be unrelated to the issue).
In any case, a few days ago I found my RV to have lost all house battery charge. Not sure of anything, I started charging it from 115v, and after a couple of days it charged. I left it on 115v for a few more days as I was busy, and only now I looked closer.
It seems that the inverter is "inverting", however pressing the On/Off button on the inverter remote control inside the cab, does NOT turn it on and off and it stays on!
When I press the on off button on the inverter remote control, nothing happens, and if I long-press it, it makes very quiet short beeps and just refuses to turn off.
As it is inverting, it is running down the battery needlessly.
Since it was late in the day, I reached into the compartment with the inverter and turned off the switch on the inverter itself. I think that it did the trick.
The remote is "RC7 GS".
To help myself troubleshoot it, I tried running the generator and the main engine, none of which made any difference and I was still unable to shut off the inverter with the remote.
My question is, how could this be. is there something that I am missing?
Thanks
Thanks
