2oldman
Jun 04, 2013Explorer II
lfeather wrote:Bulk charge is supposed to be about that voltage..and it should climb as the batteries charge. You can verify that in the Setup menu. (or owner manual) 14.4 is an absorbtion voltage.
e inverter went to bulk charge but only at 13.5 volts or so. I usually see 14.4 or so charge volts. I think I saw 92 amps DC charge rate on the led.
Xantrex is not junk. I had a very reliable Prosine for 10 years.
