HI,
I would also suggest checking the charger settings. You can adjust it to limit the pass through amperage to the inverter to limit it's power consumption to only say 5 or 10 amps. This will limit the charger's output amperage. Still it should be charging overnight when nothing else is in use.
I have a 1997 Trace inverter, and no plans on buying another Trace or Xantrex product. My plan is to look at Outback inverters or chargers next time.
Good luck,
Fred.
You might want to call the owners of this website, they repaired my Trace inverter many years ago.
SOlarOnSale.com
