rcpd34 wrote:
I put XM on my class C. I put the antenna on the dash; no dice. The loft interfered with the reception terribly. I then out it way out in the fender as far as it would go and it was much better, but still spotty in some directions. Where do you guys put it. Obviously the roof would be the best place, but it looks like a pain to wire. Ideas?
I placed mine under the forward vent cover over the loft. It sits overtop the screen and stays in place using a washer. The plastic cover does not interrupt the signal. On my Lazy Daze there is a privacy curtain about 8 inches aft of the vent. I backed out the screws holding the runner for the curtain and placed the antenna wire inside the runner between the roof and the runner to hide the wire. I chose to run in the direction of the drivers seat. Continuing along the side of the wall along the curtain to under under the bed mattress. Then using a seam in the interior carpet to the door frame molding. Around the door frame (inside) to the dash, to the receiver.
All the wire is inside. You only see the 8 or so inches that run to the vent from the curtains and because the vent is also a hatch the extra wire coiled up inside the vent so I can open the hatch. It is above the screen with the antenna.
Took about a half hour.
John
Edit, sorry I did not realize I replied to this already. Should have read through all the replies.
