Effy's avatar
Effy
Explorer II
Aug 10, 2013
yellowing plastic
Is there any cure for the yellowing of plastic pieces on a MH? The slide corners, trim pieces, etc? My ACE is white with gel coat and of course I imagine paint mitigates this, but I don't have paint.
  • hipower wrote:
    Acetone is a great cleaning product used appropriately. It is also nasty stuff. Use it with appropriate caution.
    X-2, if your not in a well ventilated air do not use Acetone and wear plastic gloves and a mask! I worked around that stuff a lot in the 70's!
  • I painted the door glass plastic frame, the stove vent and the outside shower door.
    I used regular Krylon Semi-Gloss White 2 years ago and when we traded in April, they looked as good as the day I painted them
  • Francesca Knowles wrote:
    Fusion's a good paint for plastic, but expensive at over ten bucks a can.
    Just bought a can of Fusion today for my fridge vent. $3.80 at a local auto parts store....
  • ScottG wrote:
    As Donn suggested above, I painted all the plastic parts with Krylon Fusion and it has held up surprisingly well. I'm not too keen on Krylon as a rule but the Fusion is a different formula and does a great job. Doesn't even look painted - just looks like it came that way.
    Hot tip from Camp Cheapskate:
    Rustoleum makes a primer for plastic. Any paint can be used for a topcoat....as I found out after I spent eleventy-bazillion bucks repainting the Grandkids' electric Jeep. Could have done it for a fraction of the cost if I'd known about the plastic primer. I could have used off-the shelf store brand for the topcoat! :(
    Five bucks at Walmart
  • That Awsome/Amaze cleaner from the various Dollar Stores works surprisingly well on Plastic such as the Refer Vents! Spray on and Wipe off!
  • As Donn suggested above, I painted all the plastic parts with Krylon Fusion and it has held up surprisingly well. I'm not too keen on Krylon as a rule but the Fusion is a different formula and does a great job. Doesn't even look painted - just looks like it came that way.
  • If you choose to replace many of the trim pieces are available at www.pellandent.com
  • Acetone is a great cleaning product used appropriately. It is also nasty stuff. Use it with appropriate caution.
  • Gjac's avatar
    Gjac
    Explorer III
    I use acetone for yellowed plastic parts or moldy rubber trim. My refer vent cover is 16 years old and every 3 years or so I clean it with acetone and is now white. Use a white cloth and don't saturate, acetone is a solvent and will remove the yellow or mold quickly.
  • Ask the mfg for the paint color code, and buy yourself some to paint them with. As an alternative Krylon makes plastic paint in spray cans that works wonders.
