OFDPOS
Aug 09, 2017Explorer
Totally agree on "what were the engineers thinking when they build an engine around an oil filter or fill in blank _________ "! Everyone of them needs to have to work on them ... lol
Yes JD got out early to beat the sun, once its over the tree tops from the neighbors house, it forget about working on anything till the sun goes down behind the trees of our neighbor's house. Then its everything is heat soaked !
Will see if its the same video I've watched before Thanks !
Man you ain't kidding ford did the cheapest route they could do on supplying MH manufacturers on cut away chassis.
Or its a coup between the chassis manufacturers, MH manufacturers and the aftermarket knowing darn well we the end consumer will have to do so much to correct what should have been done right in the first place !
Looking forward to test driving it this morning and I'll report back .
38,777 PostsLatest Activity: May 24, 2026
