2ndhom's avatar
2ndhom
Yet Another 6 Volt Battery Question ....
So I'm in the market for ( 4 ) new coach batteries. The ones I have are 5 years old and not holding a charge as long as they should. I've read buy "Costco, Interstate, NAPA, Maintenance Free, Gel Filled, Water Filled" etc etc. Could I hear the Pros and Cons one more time? I don't have a problem with maintenance because I'm in that routine and that's okay!! I decided after cleaning up the white powder in the bottom of the tray ... time to replace the batts. Appreciate all the supportive input!!
  • If your boondock a lot. Go with the Trojans. They probably set the standard.
    If you boondock seldom (like myself) go with either a Sams or COSTCO battery. I've used the COSTCO batteries for 9 years of fulltiming and do a good job. No complaints.
  • I've bought several Costco 6v's, have had zero problems with any of them and the price is about as low as you can get. I sure wouldn't spend the money on AGM or Trojans. Just my opinion based on my own experience.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    Brands: There are very few battery makers, Most companies, IE: Interstate, just re-label other people's batteries (often US-battery or Johnson Controls in Interstate's case. some folks Excide)
    Trojan batteries (Flooded wet cell) Do seem to be very high quality (More so than the average) as do Lifeline in the AGM side. They also cost more.
    There are a few other companies out there I do not know much about but have read about.. Costco, Sam's. And many other companies buy from JC or US.
    Now, Flooded or "other"
    Flooded wet cells are the most "Labor intensive" since you need to clean and water (Distilled only) Them from time to time.
    The Six Volt GC-2 is usually the most amp hours per dollar of any type. (NOTE you need two of them though,,, And this statement takes that into account).
    AGM, is among the least labor intensive (Occasional terminal cleaning, Every few years, that's all),. GEL is seriously NOT recommended for RV use.
    Finally Lead Acid batteries come in another 3 (well 4) way division
    Automotive starting are designed for short blasts of high current, they are rated in COLD CRANKING AMPS (Amps peak at 0 (f)
    Marine Batteries are like the above but rated in Cranking amps (0 Degrees C)
    These batteries do not like being run down much and may not recover if you run 'em down too far.
    Marine/Deep cycle can be run down a BIT more than the above and may have a slightly better recovery profile.. But not much.
    DEEP CYCLE can be run down to 50%, some lower, but most 50%, And if you run 'em down below that they may loose a bit of life, but they stand the best chance of recovery if promptly recharged.
    The common GC-2 Six Volt Golf Car battery,,,, IS A DEEP CYCLE, not a marine deep cycle, not an automotove starting (Though a pair of 'em can usually do that job just fine) but a true DEEP CYCLE battery, 230 amp hours worth.
  • 100+ watts of solar will have whatever you choose operating better and lasting longer.
  • I had Interstate in my Coach and they finally died after 7 years. With the amount of dry camping I do(and its alot) I thought that amount of time was well beyond usual so I purchased the exact Interstate batteries again and am very happy. Good luck in your search.
  • I just replaced mine (only have 2) I got them at Sams Club Exides CG2.
    $109.00 each. They have been in a month now and very happy with them.
