Grandpere
Apr 29, 2015Explorer
Yes, you figured correctly at 95 and 85 pounds. Now if I were doing it, I would run 100 pounds in all the tires for the sake of simplicity. After all, the tires are going to age out before they wear out so even wear is not a concern. Also, with the little extra air pressure the front tires will run a little cooler and it should not effect the ride quality.
