Ivylog
Apr 29, 2015Explorer III
Given that it's camper ready then I would go 5 over on the front... 100. There is no need to go 5 over on the rear because at 85 you are good for 4770 which is already 400 lbs more than what each tire needs to carry. The 85 psi is the minimum needed to keep the tire on the rim and not flex too much but if you adjust the table downward... 75 would be enough for your 4363 so at 85 you are already 10 psi over.
