tropical36 wrote:
First how many are aware that you can pull up on any truck scales along the interstates and I have never found one who wasn't more than happy to weigh you?
If you only go by stickers on your coach, what happens if you're overloaded like so many are, before they even leave the driveway?
How many of you that do weigh, only weigh each axle, like I do and if so, how do you know if one side weighs a lot more or will get that way during your travels?
How about when you leave Death Valley CA one morning and go up to Yosemite National park and where do you stop along the way to to air up your tires because of the change in ambient temps. I mean there's snow up there on Tioga Pass in the summer, folks.
Load inflation chart is the only way to go IMO and again, add the 10 - 15psi to take care of these possible variables.
Also and recently learned is that even though you might have plenty of CCC to burn, it doesn't mean that it's going to be evenly distributed and no matter how hard you try. With our new to us and present coach, we're about a ton to the good on the front, but 160lbs over on the rear. A paltry amount I know, but still and just saying that one never knows without weighing. Still don't know if both rear sides are equal and there's no way I'm going with that exact weight with the load inflation tables.
I think you'll find that most all blowouts occur with under inflated tires, unless it's due to a road hazard or advanced age, of course.
Here's a tip and even if you do run over something in the road, causing a blowout and damage to the inner fender and beyond, don't report this road hazard to your insurance company, otherwise it will go on record as a collision, rather than be treated as a comprehensive thing. In other words, you don't have a clue as to what happened, which is usually the case anyway.
