Dale_Traveling
Dec 10, 2020Explorer II
dalefuji wrote:
,,, Why can't I cut space in center and when I slide screen on rail place strap in center,????
No reason why you can't. Just keep the hole as small as possible, come up with something to seal the edges of the hole to prevent fraying and you'll need something to hold the strap out of the way since you won't be able to slide it to one side and candy cane it around an awning side rail.
For other readers, the EZ Zip Blocker Sun Screen is a two piece screen with a short section that is meant to stay on the awning roller and the majority of the screen is added when needed.
I made my own and just install it when needed which actually isn't all that often.
