A1B00902
May 18, 2015Explorer
The best way to clean your cast iron fry pan,
cover bottom with 1/4 cup of SALT put pan on burner, and heat till salt starts to brown,take off burner,then with a thick rag hold handle, with rag in other hand rub the salt around the pan in a circle till clean, be careful it will be very hot
this is a method to season a new pan also never put cast iron pans in water
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
