- jnharleyExplorerWhen we had an RV oven, we used a pizza stone. It did break but did not diminish the effectiveness of the pizza stone.
- turtlebdExplorerBuy an oven thermometer to check your inside temperature. I've found mine runs a bit off from the dial set. I also use a pizza stone placed on the bottom of the oven. Place your pans on the regular oven rack, and switch halfway through. I use my oven quite often, but hate having to practically sit on the floor to reach in and light the pilot! Wish it had a push-button start! Good luck with your muffins!!
- hilldudeExplorer
mrquacker wrote:
Use the wire rack.
Just a side question (I'm about to use the oven for the first time, too): Do you still use the wire rack for cooking or place the muffin pan directly on the pizza stone? - ksg5000Explorer IISuitably sized unglazed tile is an inexpensive way to level the temp in any RV oven - pick one up at any Big Box. Never made biscuits in my oven so I can't help much with that.
- JnJnKatiebugExplorerThe best solution we have found is to use two muffin pans stacked (an empty under the filled one). Our cornbread muffins come out perfect. We tried the pizza stone but the double pans work better for us.
For biscuits we use an air bake cookie sheet. It works perfect as well. - NYCgrrlExplorer
I will say yes because the principle is the same as your S+B oven; indirect heat is your friend for even cooking during most baking. The wire rack allows this to happen. - coolmom42Explorer II^^^^Use the wire rack.
The pizza stone only serves to even up the heat distribution, and moderate the temp swings.
I would much prefer a 2 burner cooktop with no oven. I've never used all 3 burners. - mrquackerExplorerJust a side question (I'm about to use the oven for the first time, too): Do you still use the wire rack for cooking or place the muffin pan directly on the pizza stone?
- NYCgrrlExplorerNo gasp here:).
From what I've read an RV oven is one of the least utilised cooking appliance in the kitchen.
Yes to using a paver/ pizza stone or big box store 2-3 buck unglazed quarry tile( prolly the least expensive option;))and changing position of muffin tin to accommodate the heating elements cold spots. You can also line each tin with parchment paper or use the cupcake/muffin paper liners to cut down on burnt bottoms and clean up.
Chocolate muffins, ehh?
Got recipe? - bob213ExplorerWe put our pizza stone on the solid metal shelf below the wire cooking rack. Just don't cover the holes in the solid shelf. I got a square that fits perfect from California Pizza Stones. Big difference.
About Chefs on the Road
2,136 PostsLatest Activity: Jul 25, 2025
