Want to grill your lobbies the Cook Illustrated way?
Cook's Illustrated Grilled Lobster wrote:
Charcoal-Grilled Lobsters
Published February 12, 2007.
Why this recipe works:
For a lobster recipe in which the smoky grilled flavors would penetrate the meat, we found that simply splitting the lobsters in half was the way to go. Starting them cut side down and then flipping them after two minutes kept moisture loss to a minimum. To allow the claws to finish cooking at the same time as the tail meat in our grilled lobster recipe, we cracked one side of each claw and cooked them covered with an aluminum pie plate.
less
Serves 2 as a main course, 4 as an appetizer
Be sure not to overcook the lobster; like other shellfish, lobster meat gets tough when cooked for too long. The lobsters are done when the tomalley mixture is bubbling and the tail meat has turned a creamy opaque white. Have all garlic and parsley minced and the breadcrumbs ready before you start the grill. For the breadcrumbs, use bread that is a few days old, cut it into 1/2-inch cubes, and pulse the cubes in a food processor until they turn into fine crumbs. Don't halve the lobsters until the charcoal has been lit. Use the butter variations listed at the bottom, if desired.
Ingredients
6 tablespoons unsalted butter (3/4 stick), melted
2 medium cloves garlic, minced or pressed through a garlic press (about 2 teaspoons)
2 live lobsters (each 1 1/2 to 2 pounds)
1/4 cup fresh bread crumbs
2 tablespoons minced fresh parsley leaves
Vegetable oil for cooking grate
2 9-inch disposable pie plates or small roasting pans
Lemon wedges
Instructions
1. Light large chimney starter filled with charcoal (6 quarts, about 100 briquettes) and allow to burn until all coals are covered with layer of fine gray ash. Empty coals into grill and build single-level fire by spreading coals evenly over bottom of grill. Set cooking grate in place, cover grill, and heat until grate is hot, about 5 minutes. S****e cooking grate clean with grill brush. Grill is ready when coals are medium-hot.
2. Meanwhile, mix butter and garlic together in small bowl. Split lobsters in half lengthwise, according to illustrations below, removing stomach sac and intestinal tract. Scoop out green tomalley and place in medium bowl. Using back of chef's knife, whack one side of each claw, just to make opening (this will help accelerate cooking). Add breadcrumbs, parsley, and 2 tablespoons of melted garlic butter to bowl with tomalley. Use fork to mix together, breaking up tomalley at same time. Season lightly with salt and pepper to taste.
3. Season tail meat with salt and pepper to taste. Brush cut side of lobster halves with some of remaining garlic butter. Take lobsters to grill on large tray. Lightly dip small wad of paper towels in vegetable oil; holding wad with long-handled tongs, wipe cooking grate.
4. Place lobsters on grill flesh side down. Grill, uncovered, for 2 minutes. Transfer lobsters to tray, turning them shell side down. Spoon tomalley mixture evenly into open cavities of all four lobster halves. Place lobsters back onto grill, shell-side down. Baste lobsters with remaining garlic butter and cover claws with disposable aluminum pie plates or roasting pans. Grill until tail meat turns opaque creamy white color and tomalley mixture is bubbly and has begun to brown on top, 4 to 6 minutes.
5. Serve lobsters immediately with lemon wedges. Use lobster picks to get meat from inside claws and knuckles.
Oh and IMO no frou frou lobster specific tools are needed. Cutting the lobster in half? Just break the shoulder joint against itself and you are holding a full arm in hand. Now gently break the "thumb" of the claw against itself and the entire claw meat can be pulled from the hole. Knuckle joints are the hardest but still doable. Once again break in the middle against the joint; you might need a napkin to protect your hands since the carcass is "prickly" here.
Serving it whole? Break off the tail at the last body joint, cut soft underside skeleton w/ a knife and follow the above instructions.
Signed,
a CaveWoman Serial Lobster Killer:B
