Y-Guy
Dec 30, 2020Moderator
I've never used a propane smoker, only a pellet smoker so your mileage may vary.
I always (always) brine my turkey for at least 24 hours. IMHO doesn't matter what brine you use but its a must do for me. The Traeger Orange Brine and Turkey Rub kit is good, but Costco has one and spice island turkey brine kit worked well for us too.
Day of my smoke I drain the turkey, pat it down well. Put some rub (I like the
McCormick Smokehouse Maple Seasoning) use about 2 table spoons to coat the cavity, the more outside. Also separate the skin from the meat and spread butter around. Sometimes I mix the butter in with seasoning. Letting it rest in the fridge for an hour is nice but honestly I've only done it a few times.
Then I fire up the smoker and set the "Smoke" or about 180-225° generally for about 4 hours or until you hit about 110° internal temperature, then increase the smoker to 350° until your internal temp reaches 160° - depending on your setup the total time on the grill might be 4 hours, I just don't know enough about a propane smoker to help on that aspect.
Good luck & enjoy!
Good luck & enjoy!
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
