Vintage465
Dec 30, 2020Nomad
Y-Guy wrote:
I've never used a propane smoker, only a pellet smoker so your mileage may vary.
I always (always) brine my turkey for at least 24 hours. IMHO doesn't matter what brine you use but its a must do for me. The Traeger Orange Brine and Turkey Rub kit is good, but Costco has one and spice island turkey brine kit worked well for us too.
Day of my smoke I drain the turkey, pat it down well. Put some rub (I like the
McCormick Smokehouse Maple Seasoning) use about 2 table spoons to coat the cavity, the more outside. Also separate the skin from the meat and spread butter around. Sometimes I mix the butter in with seasoning. Letting it rest in the fridge for an hour is nice but honestly I've only done it a few times.
Then I fire up the smoker and set the "Smoke" or about 180-225° generally for about 4 hours or until you hit about 110° internal temperature, then increase the smoker to 350° until your internal temp reaches 160° - depending on your setup the total time on the grill might be 4 hours, I just don't know enough about a propane smoker to help on that aspect.
Good luck & enjoy!
There would be little I could add to this. Be certain your brine is real cold, like ice cold or in a fridge over night. I make my own simple brine with 1/2 cup salt 1/4 cup sugar and 1 cup soy sauce. Kinda fun to add some fresh garlic smashed up and maybe some rosemary. Brining is real important to the great flavor of a smoked turkey as the salt penetrates the meat it takes water with it and that keeps it real moist at the time of completion as well as enhancing the flavor. I never need to "part the bird out" but breaking down the turkey shouldn't be to difficult if it's thawed. Just cut at the joints. I would prolly separate the back...then cut the bird in half and brine it along with the back. If you remove the leg/thigh from the carcass it will cook easier but you will lose a certain amount of moisture that way. If you do the brine above wiht chicken overnight and smoked whole, the results are outrageous.
Have fun!
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
