propchef
Jan 07, 2021Explorer
Great tips!
- Brining isn't "curing" but does a few things. Flavor, of course, but it helps the very lean meat retain moisture. It also give you some "wiggle room" around doneness. IOW, if you overcook it it doesn't dry out.
- Soy sauce should be avoided in any brine as it throws off the salt %. A turkey shouldn't be brined longer than 24 hours. A chicken can be brined in about 90 minutes.
- For the meat to take the smoke, let the sit in the refrigerator UNCOVERED for a few hours. The surface of the meat will dry and become tacky. This is known as a "pellicle" gives something for the smoke to adhere to.
- Gas is a very dry heat and will pull the moisture out of anything it cooks. Seasoned wood has the most moisture with lump charcoal a close second.
- Smoking chips. Use the largest size chips you can find. Some brands are nearly sawdust. Avoid these.
- It isn't necessary to soak chips. The fire will only dry the chips first, and only then will they produce smoke. The key is to keep the o2 levels low by using the lid or draft doors.
- DON'T OVERSMOKE. A large turkey only needs about 30 minutes of actual smoke. I try to add my smoking chips about 30 minutes into the cooking process. Over smoking is bad.
- Get a good wireless thermometer. Dark meat needs to be 180 but the breast is done at 165. The automatic "pop-up" timers go off somewhere between 190 and 225.
- Save the bones and make stock!
Here's my video on how to cut a chicken. It's the same anatomy for a turkey.
https://youtu.be/k6g0wClvASM
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
