CA_Traveler
Sep 29, 2020Explorer III
This is my high pressure adapter with a El (for hose routing considerations) and a shutoff valve. The top external tank port came with the adapter. The BBQ connector is the standard 1lb 1" screw on propane bottle type.
Click For Full-Size Image.
Hoses with the standard 1” screw on adapters are available. And an adapter for the standard BBQ regulator fitting are available. Propane stores can also make custom length hoses however I use 1 or 2 12' hoses as needed.
Here are the parts that connect to any grill.
About Chefs on the Road
2,136 PostsLatest Activity: Mar 11, 2025
