bob_nestor
Sep 30, 2020Explorer III
Old-Biscuit wrote:
48" in stock (72" and 120" Out of stock)
MB Sturgis quick connect hose...replace 1 lb bottles
A great source for all things propane is:
https://caloreequipment.com/
They also carry both high pressure and low pressure connects - the two are NOT compatible. RVs made before about 2007 with quick connects typically used high pressure fittings because they weren't pressure regulated; RVs made after that typically use the low pressure connects since they are downstream of the main regulator. I believe the industry standards now require the quick connects to be pressure regulated thus the use of the low pressure quick connects.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
