You can get by without buying special tools. Channel Locks are always in my rig and they also make great lid lifters, just hook the upper jaw under the handle. Something to set the lid on is handy and a pie tin works well for that.
The biggest item I can't do without is a pan to cook in. I use 2 metal pans, the ones used to change your oil, that are painted with grill black. I invert one and hold the bottoms together with a bolt and wing nut. I reverse them for storage. These work great and can even be used on grass without burning it.
