propchef wrote:
valhalla360 wrote:
If it's dedicated to campfire cooking, I would just get a bag and stick it in sooty.
Avoid soap on cast iron. It removes the seasoning and food will stick.
Sorry, but this is a cast-iron myth. I use hot soapy water on mine every time I use them, and I use them almost daily. No sticking issues ever.
As Magnus mentions, cast iron is tough. NOT washing leaves off-flavored residue and potentially rancid oils. Like any pan, they must be washed with soap and hot water.
There are only two no-no's: excessive heat and putting them away wet. After washing, put it back on low heat and allow it to dry completely. No soot issues ever.
Never said, don't wash it. Just not with soap, particularly a strong degreasing soap. While hot, a bit of water and paper towel will remove the food residue if properly seasoned (never had off flavors and my Mom never let us use soap on the cast iron). If not well seasoned, steel wool will typically do the trick.
If you are using them daily, the new oil added probably negates some of the downside of using soap. Particularly if the pan is hot, so you are effectively doing a quasi-seasoning.
Rocket hot is one area where cast iron shines. Spatchcock a chicken then get two cast iron pans near red hot and put the chicken in the bigger pan and set the smaller on top so it cooks from both sides (in this case, the bottom of the small pan needs to be clean and seasoned).
Keeping it dry in storage, I'll agree whole heartedly but even that is salvageable unless the rust gets extreme.
