NYCgrrl
Feb 26, 2017Explorer
TenOC wrote:
I am looking for a good french onion soup receipt. I noticed some add flour to the broth/onions. I assume to thicken the broth. Any other reason????
In France, you can use flour, or not, and water to replace the broth. About the only absolutes are carmelised onions and a melting cheese on the bread.
In the Parisian version that most Americans know, the traditional ingredient list is: flour, onions, beef broth, Comte cheese, and bread slices.
You pegged it, 10OC, the flour is used as a thickener and the ratio is about 1 TB flour per every 1-2/3 lb of onions.
Here's a modern (and flour-less) way to make it using a crock pot:
http://www.thekitchn.com/how-to-make-french-onion-soup-in-the-slow-cooker-start-to-finish-cooking-lessons-from-the-kitchn-215696
Comte cheese can be readily substituted with Gruyere, Swiss/Ememental or Raclette. We often find ourselves with leftover bread since there is only 2 bread eaters in the house on a regular basis so I slice French bread on the diagonal, and place it in the freezer for later use. Great for stuffings and onion soup croutons since there's less moisture in it.
The soup freezes nicely minus the croutons, as do just carmelised onions which can be used as a base for the soup or say an omelette or burger topping. Look with in the above hyperlink and you'll find a recipe for crock pot carmelised onions.
HTH
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
