Does anyone use an electric grill and if so which one? We are thinking it would be nice not to have to mess with LP or charcoal. As of now I believe we want to go with a Weber just not sure if it will be gas or electric. The motorhome has a generator so electric wouldn't be a problem when boon docking.
IMHO I found it to be a big draw on the generator. Especially the griddles and fry pans because they continually go on and off to maintain temp causing spike draws.
Don't plan on using your AC while you are using an electric frying pan or BBQ using the gen. If the air is coming on the same time as the griddle is cycling it will usually trip. Unless you have a class a with a big diesel gen.
