wca01's avatar
wca01
Nesting Cookware
For those who need nesting cookware, Magma provides a great choice. Magma is an upscale provider of high quality, mostly stainless steel, products for the marine community that includes portable grilles and nesting cookware. All of their products are made for the harsh marine environment and are long lasting. While I was in the yachting world, I used their grilles. They are great, but maybe a little pricey for RV use.
The cookware comes in a set of 10 with two accessory items available. The basic set includes two removable handles. The entire set, including the two accessory pieces, can be nested together into a less than ½ cu. ft. package. The removable handles must be stored separately.
The set comes in four flavors. Stainless steel non-induction and induction – stainless steel with non-stick surface non-induction and induction. The non-stick surface is ceramic and called “Ceramica.” I use the non-stick induction version and the non-stick surface is very good.
The basic set includes:
10 inch diameter Sauté/ Fry Pan, Lid for Stock Pot/ Sauté Fry Pan, Lid that fits all Saucepans, 1-1/2 qt. Saucepan, 2 qt. Saucepan, 3 qt. Saucepan, 5 qt. Stock Pot, 2 Removable Handles, “Bungee” Storage Cord.
The accessories are a Sauté/Omelette Pan (about 9.75” diameter at the top) with sloping sides for easy flipping and a Stainless Steel Colander, Steamer, Crab & Pasta Cooker.
Aside from the small storage space required, the set is oven safe to 500 degrees F. Since you can remove the handles, you can use this cookware in a RV convection oven with a rotating carousel.
It is very good, but expensive. If you are interested, you can check it out at http://www.magmaproducts.com/index.html. The best prices can most often found at Amazon.
Good Luck!
Wil
  • It looks very nice! Maybe I'll give it to myself this coming Christmas! :)
