Rolling_Condo
Jun 01, 2016Explorer II
magnusfide wrote:
I use the Kingsford original. It's an easy start, reliably holds the heat in a steady burn and lumps last a bit longer too without going out. A chimney starter is always a good investment for better starts as well.
That sums it up for using the original. Most important for using when cooking with Dutch Ovens as you want constant and consistent heat.
About Chefs on the Road
2,136 PostsLatest Activity: Sep 09, 2026
