SWMO
Nov 26, 2013Explorer
SETenn wrote:
It is 35 degrees and raining right now and the max temp I could get was 235 degrees,
That will work, it would be tough with a whole bird, but I believe you said you were doing a breast. I would plan on using the water when you're applying smoke then pull it out and wrap the breast in foil for the finish. Pulling the water should up the temperature a little and wrapping will keep the moisture in. If you have a couple hours of heavy smoke that should plenty.
About Chefs on the Road
2,136 PostsLatest Activity: Jun 27, 2014
