georgeguenther's avatar
Jul 26, 2020
Hello all
I just bought a used camper that's in excellent condition, I just have one problem...the water heater. The tank gets hot and every now and then you get a burst of hot water. The guy I bought it from said he had a problem with the check valve on the top. I replaced the check valve today and it's still just giving me a burst of hot water when I turn it on the goes back to cold. Any help would be greatly appreciated! Thank you.
  • OTOH It's not a hard part to switch out, this grandma has put in a new water heater.
  • Are you sure the outside shower (or inside) doesn't have the valves open but the showerhead closed? That is a frequent issue that "short circuits" the hot water.
  • 2112's avatar
    2112
    Explorer II
    Perhaps the bypass valve is open. Different builders use different valves but this pic may help. Assure the center valve is closed
About RV Families
501 PostsLatest Activity: Apr 24, 2025
