jepalmer's avatar
jepalmer
tying up dogs
newbie question:
When sitting outside, how/where do you tie up the dog's lead?
The Dachshund won't be much of a problem, but the lab mix is a puller.....
Thanks
  • We use a steel cable attached to the trailer. It's frightening to anyone passing by your campsite it your large dog lunges at them, tied or not. You should train your dog not to do that.
  • We use either the picnic table or one of the corkscrew stakes linked to above for our larger dog. Our smaller dog gets hooked to the RV steps.
  • downtheroad wrote:
    We tie ours to the leg of the chair we are sitting in. That way we can completely keep track of what they are up to and can control them. If we both leave and go inside, they go inside.
    x2
  • Those pens are nice except my present blue heeler & last dog a border collie jump into the pickup bed when I get in to go someplace. I would need a pen over 6 ft high.
  • We tie ours to the leg of the chair we are sitting in. That way we can completely keep track of what they are up to and can control them. If we both leave and go inside, they go inside.
  • Depending on the situation, I usually use either the rear jack assembly or around one of the wheel spokes. Obviously, you have to be careful you don't forget to detach the cable(s) before you pull out. One time, I almost pulled out without detaching a cable from one of my wheel spokes!:E
    No, I have never forgotten to detach the dog(s) before pulling out!
    :E
