rerod's avatar
rerod
12 volt Smart TV?
I know some people have had good luck buying a TV with 120v/12v transformers, and powering them from the RV's 12 volt system without the TV transformer or a inverter. I read you need to go to the store and look at the transformer to be sure its 12 volt since manufactures don't generally list that info..
So my question is.. Do any smart TV's come with a 120v/12v transformer? I need a new tv and it would be nice to be able to watch it at home and while camping in the RV..
Thanks!
  • RoyB's avatar
    RoyB
    Explorer II
    Usually the 120VAC HDTVs I have seen at the stores that has the 120VAC Transformer modules is usually a 15-19VDC source required. This has worked great for me in the past. My on-board converter/charger can have as high as 14.4VDC on the 12VDC grid so having the 15V-19VDC TV voltage requirement was great.
    They used be very common things to have in the older TVs but these days most of them have built-in power supplies and only work off 120VAC...
    When you go to the stores just look behind all of the TVs they have on display and I bet all you see will not be using an external transformer module. Very rare to find one that still uses them.
    For me the HDTV was only half the problem. The other things like DVDs, SAT RCVRs, Cell Phone and Computer chargers, etc will probably also need to be fired up when you are camping of the power grid. I ended up with a 600W PURE SIGN WAVE Inverter to handle all of the things we wanted to have ON when camping off the power grid. We normally use right at 300WATTS being pulled from our Pure Sign Wave Inverter so purchased one with double that output to be to able to handle anything else we might want to add to it...
    It is all what you want to do
    Roy Ken
  • sch911 wrote:
    Any TV with an AC to DC power brick will have the Input and Output voltages listed on the brick. So there is no need to go to the store and test. Most smaller LCD TV's would use some sort of power brick. As far as Smart TV's are concerned, what do you mean? Internet enabled for apps like Netflix?
    I cant find any voltage info regarding the brick when I shop online. Thus, I'd have to go to the store and read the brick. Not test.
    Yes.. Netflix etc. But maybe a dumb TV with a Roku 3 would be a better choice.
  • Any TV with an AC to DC power brick will have the Input and Output voltages listed on the brick. So there is no need to go to the store and test. Most smaller LCD TV's would use some sort of power brick. As far as Smart TV's are concerned, what do you mean? Internet enabled for apps like Netflix?
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Dec 01, 2025
