kirbybear's avatar
kirbybear
12 Volt Timer Relay
I have a in bed fuel tank with a pump to move the fuel to the main tank. I like to run the pump at 10 minute intervals to keep the main tank full. However due to advanced age I tend to forget to turn the manual switch off !
I have done a Google search and fail to find a compact 12 volt 10 minute timer/relay.
Anyone know of a supplier ? Thanks Bob
  • Thanks for the novel response. I went with the Wolstentech relay. Bob
  • Well you certainly have more experience than I do plus I have been out of practice for the past 20 years.
    I have used a simple diode up to reversed zeners for snubbers or more elaborate setups for switching power supplies to eliminate RF noise I don't remember referring to the circuits we used as snubbers we just had to eliminate the arcing and RF.
    I am not arguing or disagreeing with you I just did not think about it in this case due to low voltage and the application.
  • Garry,
    Those timers must be used with a snubber in certain DC applications:
    When the contacts open the inductive kick back from the motor will start an arc between the contacts.
    Two things can happen.
    1. The contacts will be eventually destroyed. :(
    or
    2. The contacts will be welded together. :(
    The series RC (snubber) circuit slows down the voltage rise across the contacts, thus preventing the arc from forming. :)
  • Timers for bathroom infrared lamps are available as mechanical timers used in many hotels.
    Can be used with 12VDC and available from Lowe's or Home Depot.
  • 96Bounder30E wrote:
    How about using a 15 minute spring wound timer?......cheap and plentiful........and it doesn't care what voltage you are running through it.....(12V DC or 120V AC)
    I know that timer well, having been the Chief Test Equipment Engineer at Intermatic.
    It will work rather well but when using it on a DC circuit you'll need a "snubber" across the leads.
    ----^v^v^v^v^v^v^v----|(----
    The resistor is 47 Ohms 1 Watt and the capacitor is 1 µF @ 100 Volts.
    The snubber is to kill the arc when the contacts open.
  • What's wrong with just watching the fuel gauge, then pumping ONCE when you need it?
    If that's also a problem, reset your trip odometer every fillup, and use that as your gauge.
  • RoyB's avatar
    RoyB
    Explorer III
    X2 what 96Bounder30E says...
    Great to have around RV for things like that.
    Roy Ken
  • How about using a 15 minute spring wound timer?......cheap and plentiful........and it doesn't care what voltage you are running through it.....(12V DC or 120V AC)
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 19, 2026
